주요 콘텐츠로 건너뛰기
Proscan Tablet Camera Replacement
필요한 것
  1. Proscan Tablet Camera Replacement, Camera: 1 단계, 이미지 1/1
    • Tools necessary for task. Starting from the left to right Metal Spudyer Plastic opening tool Precision tweezer Point pen tool Driver with bit size J0
  2. Proscan Tablet Camera Replacement: 2 단계, 이미지 1/1
    • The backing of the tablet is fastened by simply snapping it in. Using the metal opening tool, pry between the plastic backing and the edge, but do not remove it yet. Work your way around until you have them separated.
  3. Proscan Tablet Camera Replacement: 3 단계, 이미지 1/1
    • Once you have finished going around the edges of the tablet, look inside.
  4. Proscan Tablet Camera Replacement: 4 단계, 이미지 1/1
    • You can directly locate and remove the camera component in the corner. Simply unscrew the piece and gently remove the tape wire.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cameron Denny
회원 가입일: 10/23/15
321 평판
안내서 2개 작성하였습니다
University of Memphis, Team 3-3, Kim Fall 2015 University of Memphis, Team 3-3, Kim Fall 2015 회원
UM-KIM-F15S3G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 390
