주요 콘텐츠로 건너뛰기
Protocol Dronium Two HD Camera Replacement
필요한 것
  1. Protocol Dronium Two HD Camera Replacement, Landing Gear: 1 단계, 이미지 1/1
    • Turn device off by moving the selector switch to the left.
  2. Protocol Dronium Two HD Camera Replacement: 2 단계, 이미지 1/2 Protocol Dronium Two HD Camera Replacement: 2 단계, 이미지 2/2
    • Place one hand on the drone and carefully remove the landing gear with the other hand.
    • Be gentle as to not break off the studs on the landing gear.
  3. Protocol Dronium Two HD Camera Replacement, HD Camera: 3 단계, 이미지 1/2 Protocol Dronium Two HD Camera Replacement, HD Camera: 3 단계, 이미지 2/2
    • Use the fine edged plastic opening tool to pull up one side of the plug, and then the other, until it comes loose.
  4. Protocol Dronium Two HD Camera Replacement: 4 단계, 이미지 1/2 Protocol Dronium Two HD Camera Replacement: 4 단계, 이미지 2/2
    • Push the battery cover away from the drone and carefully open it up.
  5. Protocol Dronium Two HD Camera Replacement: 5 단계, 이미지 1/2 Protocol Dronium Two HD Camera Replacement: 5 단계, 이미지 2/2
    • Carefully remove the two Phillips 5.35 mm screws holding the camera to the battery cover.
  6. Protocol Dronium Two HD Camera Replacement: 6 단계, 이미지 1/1
    • Close the battery cover by pulling it towards you. Then, gently pull the camera towards you, freeing it from the battery cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
William Tietz
회원 가입일: 01/18/17
101 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 199
