주요 콘텐츠로 건너뛰기
Protocol Galileo Pinion Gear Replacement
필요한 것
  1. Protocol Galileo Pinion Gear Replacement, Battery: 1 단계, 이미지 1/1
    • Find door on the underside of drone. Open the door.
  2. Protocol Galileo Pinion Gear Replacement: 2 단계, 이미지 1/2 Protocol Galileo Pinion Gear Replacement: 2 단계, 이미지 2/2
    • Carefully pull out battery, pulling out wires first.
  3. Protocol Galileo Pinion Gear Replacement: 3 단계, 이미지 1/1
    • Disconnect the connecter.
    • When reconnecting, remember to match up the black wire with the black wire and the red with red.
  4. Protocol Galileo Pinion Gear Replacement, Propeller: 4 단계, 이미지 1/2 Protocol Galileo Pinion Gear Replacement, Propeller: 4 단계, 이미지 2/2
    • Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
  5. Protocol Galileo Pinion Gear Replacement: 5 단계, 이미지 1/1
    • Twist the white spindle sleeve counter clockwise to align locking pin inside with the opening.
  6. Protocol Galileo Pinion Gear Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
  7. Protocol Galileo Pinion Gear Replacement: 7 단계, 이미지 1/1
    • Pull off white spindle sleeve.
    • Take note of which side of the spindle sleeve is the top.
  8. Protocol Galileo Pinion Gear Replacement: 8 단계, 이미지 1/2 Protocol Galileo Pinion Gear Replacement: 8 단계, 이미지 2/2
    • Pull off propeller.
  9. Protocol Galileo Pinion Gear Replacement, Top Shell: 9 단계, 이미지 1/3 Protocol Galileo Pinion Gear Replacement, Top Shell: 9 단계, 이미지 2/3 Protocol Galileo Pinion Gear Replacement, Top Shell: 9 단계, 이미지 3/3
    • Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
  10. Protocol Galileo Pinion Gear Replacement: 10 단계, 이미지 1/2 Protocol Galileo Pinion Gear Replacement: 10 단계, 이미지 2/2
    • Unscrew two 9 mm screws located inside the legs. Repeat the same procedure for the other three legs
  11. Protocol Galileo Pinion Gear Replacement: 11 단계, 이미지 1/3 Protocol Galileo Pinion Gear Replacement: 11 단계, 이미지 2/3 Protocol Galileo Pinion Gear Replacement: 11 단계, 이미지 3/3
    • Unplug the camera wire.
    • Press the hold release button and slide out the camera module away from the button.
  12. Protocol Galileo Pinion Gear Replacement: 12 단계, 이미지 1/2 Protocol Galileo Pinion Gear Replacement: 12 단계, 이미지 2/2
    • Remove the motor protection cover by unscrewing two 9 mm screws using Philips #0. When the screws are off, use your fingers to pull the motor protection cover off. Repeat the procedure for the other three arms.
  13. Protocol Galileo Pinion Gear Replacement: 13 단계, 이미지 1/3 Protocol Galileo Pinion Gear Replacement: 13 단계, 이미지 2/3 Protocol Galileo Pinion Gear Replacement: 13 단계, 이미지 3/3
    • Unclip the motor cable from the shells housing using two pry tools. Repeat the same procedure for the other three arms.
  14. Protocol Galileo Pinion Gear Replacement: 14 단계, 이미지 1/1
    • Remove 3 9mm screws around the motor housing. Repeat the steps for the three other arms.
  15. Protocol Galileo Pinion Gear Replacement: 15 단계, 이미지 1/2 Protocol Galileo Pinion Gear Replacement: 15 단계, 이미지 2/2
    • Remove four 9 mm screws located where the legs originally are placed. (Use a thin head screwdriver)
  16. Protocol Galileo Pinion Gear Replacement: 16 단계, 이미지 1/3 Protocol Galileo Pinion Gear Replacement: 16 단계, 이미지 2/3 Protocol Galileo Pinion Gear Replacement: 16 단계, 이미지 3/3
    • Cut the yellow strips using a scalpel. Pry open the casing using pry tools working gently around the corners.
  17. Protocol Galileo Pinion Gear Replacement, Pinion Gear: 17 단계, 이미지 1/1
    • Remove the motor assembly from the bottom shell.
  18. Protocol Galileo Pinion Gear Replacement: 18 단계, 이미지 1/2 Protocol Galileo Pinion Gear Replacement: 18 단계, 이미지 2/2
    • Slide the pinion gear off of the motor assembly.
결론
Thomas Ramey
회원 가입일: 02/03/17
301 평판
안내서 3개 작성하였습니다
UW Tacoma, Team 2-3, Rose Winter 2017 UW Tacoma, Team 2-3, Rose Winter 2017 회원
UWT-ROSE-W17S2G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 333
