소개
Is a motor on your drone spinning but not causing the propeller to spin? Replacing the pinion gear as shown in this guide may help.
필요한 것
Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
거의 끝나갑니다!
결론
