주요 콘텐츠로 건너뛰기
Protocol Galileo Stealth Battery Replacement
  1. Protocol Galileo Stealth Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the door to the battery compartment on the underside of the drone.
  2. Protocol Galileo Stealth Battery Replacement: 2 단계, 이미지 1/1
    • Open the door to the battery compartment by pressing in the clip on the door and carefully lifting until the door is fully open.
  3. Protocol Galileo Stealth Battery Replacement: 3 단계, 이미지 1/1
    • First pull out the wires located to the side of the battery.
    • Carefully remove the battery from the battery compartment
    • The battery can be a bit difficult to remove, but if the wires are held firmly to the battery, the battery will eventually come out by lightly pulling on the battery and wires simultaneously.
    • The small black and white wire with the white plug will not be connected to the drone, just be sure the plug does not get stuck in the battery compartment and damaged while removing the battery. This is rarely an issue.
  4. Protocol Galileo Stealth Battery Replacement: 4 단계, 이미지 1/1
    • Disconnect the two ends of the wires by lightly pulling them apart.
결론
stephen R masalewicz
회원 가입일: 02/15/18
270 평판
안내서 2개 작성하였습니다
UW Stout, Team S8-G4, Ogden Spring 2018 UW Stout, Team S8-G4, Ogden Spring 2018 회원
UWSTOUT-OGDEN-S18S8G4
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Please were can buy the battery
odoffin Kehinde - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 600
