주요 콘텐츠로 건너뛰기
Protocol Galileo Stealth Light Emitting Diode (LED) Replacement
필요한 것
  1. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: 1 단계, 이미지 2개 중 1개 Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: 1 단계, 이미지 2개 중 2개
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  2. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: 2 단계, 이미지 1개 중 1개
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  3. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Light Emitting Diode (LED): 3 단계, 이미지 1개 중 1개
    • Remove 6mm Phillips #0 screw from the LED strip.
  4. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the LED strip from the housing by applying light pressure away from the lower housing with the plastic opening tool.
    • Take care not to damage the LED strip when removing it from the lower housing.
  5. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: 5 단계, 이미지 1개 중 1개
    • Unclip the wire plug from the motherboard by applying light pressure away from the motherboard with the plastic spudger.
    • Avoid damaging the wire plug, wires, and motherboard when removing the wire plug.
결론
작성자
3다른 기여자 명과 함께
Matthew Selting
회원 가입일: 02/15/18
453 평판
안내서 4개를 작성함
UW Stout, Team S8-G4, Ogden Spring 2018 UW Stout, Team S8-G4, Ogden Spring 2018 회원
UWSTOUT-OGDEN-S18S8G4
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 11
전체 시간: 253
