주요 콘텐츠로 건너뛰기
Protocol Galileo Stealth Motor Replacement
필요한 것
  1. Protocol Galileo Stealth Motor Replacement, Propeller: 1 단계, 이미지 1/1
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Motor Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Motor Replacement: 3 단계, 이미지 1/1
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Motor Replacement: 4 단계, 이미지 1/1
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Motor Replacement, Housing: 5 단계, 이미지 1/2 Protocol Galileo Stealth Motor Replacement, Housing: 5 단계, 이미지 2/2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Motor Replacement: 6 단계, 이미지 1/1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  7. Protocol Galileo Stealth Motor Replacement, Motor: 7 단계, 이미지 1/2 Protocol Galileo Stealth Motor Replacement, Motor: 7 단계, 이미지 2/2
    • Remove the 3 outer 8mm long Phillips #0 screws from the lower drone housing.
    • Remove the 2 inner 3 mm long Phillips #0 screws from the drone motor.
    • Place screws in a safe place to prevent misplacing them.
  8. Protocol Galileo Stealth Motor Replacement: 8 단계, 이미지 1/1
    • Remove the two 6mm long Phillips #0 screws from the lower motor cover located on the underside of the drone.
    • Place the screws in a safe place to prevent misplacing them.
  9. Protocol Galileo Stealth Motor Replacement: 9 단계, 이미지 1/1
    • Remove the motor cover by lightly pulling it away from the drone.
  10. Protocol Galileo Stealth Motor Replacement: 10 단계, 이미지 1/2 Protocol Galileo Stealth Motor Replacement: 10 단계, 이미지 2/2
    • Unclip the wire plug by applying light pressure to the wire plug with the plastic opening tool, and remove the motor.
    • This plug can be a bit difficult to remove, but it does not require much force to remove.
    • Avoid damaging the plug and wires when unclipping wire plug.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Selting
회원 가입일: 02/15/18
432 평판
안내서 4개 작성하였습니다
UW Stout, Team S8-G4, Ogden Spring 2018 UW Stout, Team S8-G4, Ogden Spring 2018 회원
UWSTOUT-OGDEN-S18S8G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 14
전체 시간: 1,102
