소개
This guide will walk you through how to remove the pinion gear from the motor shaft. Minimal tooling is required on the prerequisite steps, but removing the pinion gear itself requires no tools. Removing the pinion gear is very easy and should only take a few seconds to complete.
필요한 것
Lift the pinion gear off the motor shaft by lightly pulling it away from the drone.
거의 끝나갑니다!
결론
댓글 2개
where can i get pinion gears at
where can i purchase pinion gears
