주요 콘텐츠로 건너뛰기
Protocol Kaptur GPS Main Circuit Board Replacement
필요한 것
  1. Protocol Kaptur GPS Main Circuit Board Replacement, Battery: 1 단계, 이미지 2개 중 1개 Protocol Kaptur GPS Main Circuit Board Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • The battery is accessible through the back of the drone.
    • Press the tabs on both sides of the white stripe to pull the battery out.
  2. Protocol Kaptur GPS Main Circuit Board Replacement: 2 단계, 이미지 3개 중 1개 Protocol Kaptur GPS Main Circuit Board Replacement: 2 단계, 이미지 3개 중 2개 Protocol Kaptur GPS Main Circuit Board Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the screws starting with the three smaller ones on the top part of the battery.
    • Remove the three screws on the other side.
    • There are two screws tucked under where the yellow circle is located. You will need to remove the other screws first before you get to these two.
    • There should be one 7 mm Phillips head screw, three 6 mm Phillips head screws, and four 5 mm Phillips head screws.
  3. Protocol Kaptur GPS Main Circuit Board Replacement: 3 단계, 이미지 2개 중 1개 Protocol Kaptur GPS Main Circuit Board Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the top piece, and gently pry the two halves apart. Divide the sticker if necessary.
  4. Protocol Kaptur GPS Main Circuit Board Replacement: 4 단계, 이미지 2개 중 1개 Protocol Kaptur GPS Main Circuit Board Replacement: 4 단계, 이미지 2개 중 2개
    • The battery is now removable from its container.
    • During reassembly, make sure the outlet is returned to its holder and faces the correct direction.
  5. Protocol Kaptur GPS Main Circuit Board Replacement, Main Circuit Board: 5 단계, 이미지 2개 중 1개 Protocol Kaptur GPS Main Circuit Board Replacement, Main Circuit Board: 5 단계, 이미지 2개 중 2개
    • Remove the 4x 7mm screws on the top and bottom, and the 2x 5mm screws from the middle, then remove the back part of the housing.
    • Remove the two hidden screws at the bottom, and the white power button.
    • There will be 6x 7 mm Phillips head screws, and 2x 5 mm Phillips head screws.
  6. Protocol Kaptur GPS Main Circuit Board Replacement: 6 단계, 이미지 3개 중 1개 Protocol Kaptur GPS Main Circuit Board Replacement: 6 단계, 이미지 3개 중 2개 Protocol Kaptur GPS Main Circuit Board Replacement: 6 단계, 이미지 3개 중 3개
    • Unplug all the cords from the circuit boards.
    • Carefully slide the main body right off the arms.
  7. Protocol Kaptur GPS Main Circuit Board Replacement: 7 단계, 이미지 2개 중 1개 Protocol Kaptur GPS Main Circuit Board Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the four 4mm Phillips screws.
    • Desolder all cords on the circuit board, and pull the board up and out.
    • It is important to keep track of where the leads came from. Red/Blue and Black/White pairings belong to motors, whereas Black/Red pairings belong to lights. The ports are labeled on the board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Connor Woitte
회원 가입일: 02/15/18
858 평판
안내서 3개를 작성함
UW Stout, Team S8-G6, Ogden Spring 2018 UW Stout, Team S8-G6, Ogden Spring 2018 회원
UWSTOUT-OGDEN-S18S8G6
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 13
전체 시간: 907
