주요 콘텐츠로 건너뛰기
Protocol Slipstream EVO Battery Replacement
필요한 것
  1. Protocol Slipstream EVO Battery Replacement, Battery: 1 단계, 이미지 1/2 Protocol Slipstream EVO Battery Replacement, Battery: 1 단계, 이미지 2/2
    • On the bottom of the drone unscrew the screws next to the battery, using the screwdriver provided.
    • The picture shows one of the screws you will be removing, the other screw is directly across from the one being presented.
    • Tip: Removing the screws will loosen the frame of the drone allowing the battery to be removed easier. If you do not want to remove the screws skip to step 2.
  2. Protocol Slipstream EVO Battery Replacement: 2 단계, 이미지 1/3 Protocol Slipstream EVO Battery Replacement: 2 단계, 이미지 2/3 Protocol Slipstream EVO Battery Replacement: 2 단계, 이미지 3/3
    • Pinch the side of the battery that is already exposed and pull until the battery is fully removed from the drone.
  3. Protocol Slipstream EVO Battery Replacement: 3 단계, 이미지 1/3 Protocol Slipstream EVO Battery Replacement: 3 단계, 이미지 2/3 Protocol Slipstream EVO Battery Replacement: 3 단계, 이미지 3/3
    • With the replacement battery, insert it where you removed the faulty battery until it fully secured within the drone.
    • Replace screws that were removed earlier if you did not skip step 1.
결론
Michael Dang
회원 가입일: 04/10/17
301 평판
안내서 3개 작성하였습니다
UW Tacoma, Team S3-G3, Liner Spring 2017 UW Tacoma, Team S3-G3, Liner Spring 2017 회원
UWT-LINER-S17S3G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 502
