주요 콘텐츠로 건너뛰기
Protocol Slipstream EVO Propeller Guards Replacement
필요한 것
  1. Protocol Slipstream EVO Propeller Guards Replacement, Propeller Guards: 1 단계, 이미지 1/1
    • With the drone flat on the ground, identify which propeller guard you will be replacing.
    • The front of the drone is where there are no wires exposed.
  2. Protocol Slipstream EVO Propeller Guards Replacement: 2 단계, 이미지 1/2 Protocol Slipstream EVO Propeller Guards Replacement: 2 단계, 이미지 2/2
    • With the plastic opening tool, pry the side of the guard closest to the front or the back of the drone depending on where you decided to start from.
    • After prying off one side of the guard, pushing down on the same side will release the other side of the clip.
    • Repeat this step for the following side as needed.
  3. Protocol Slipstream EVO Propeller Guards Replacement: 3 단계, 이미지 1/2 Protocol Slipstream EVO Propeller Guards Replacement: 3 단계, 이미지 2/2
    • With the replacement guard line up the clips and push the clips into place.
    • After the guard has been attached to the drone, pinch the clips as you push the guards to ensure they are secured.
결론
Michael Dang
회원 가입일: 04/10/17
301 평판
안내서 3개 작성하였습니다
UW Tacoma, Team S3-G3, Liner Spring 2017 UW Tacoma, Team S3-G3, Liner Spring 2017 회원
UWT-LINER-S17S3G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 153
