주요 콘텐츠로 건너뛰기
Protocol Slipstream EVO Propeller Guards Replacement
필요한 것
  1. Protocol Slipstream EVO Propeller Guards Replacement, Propeller Guards: 1 단계, 이미지 1개 중 1개
    • With the drone flat on the ground, identify which propeller guard you will be replacing.
    • The front of the drone is where there are no wires exposed.
  2. Protocol Slipstream EVO Propeller Guards Replacement: 2 단계, 이미지 2개 중 1개 Protocol Slipstream EVO Propeller Guards Replacement: 2 단계, 이미지 2개 중 2개
    • With the plastic opening tool, pry the side of the guard closest to the front or the back of the drone depending on where you decided to start from.
    • After prying off one side of the guard, pushing down on the same side will release the other side of the clip.
    • Repeat this step for the following side as needed.
  3. Protocol Slipstream EVO Propeller Guards Replacement: 3 단계, 이미지 2개 중 1개 Protocol Slipstream EVO Propeller Guards Replacement: 3 단계, 이미지 2개 중 2개
    • With the replacement guard line up the clips and push the clips into place.
    • After the guard has been attached to the drone, pinch the clips as you push the guards to ensure they are secured.
결론
작성자
4다른 기여자 명과 함께
Michael Dang
회원 가입일: 04/10/17
301 평판
안내서 3개를 작성함
UW Tacoma, Team S3-G3, Liner Spring 2017 UW Tacoma, Team S3-G3, Liner Spring 2017 회원
UWT-LINER-S17S3G3
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 5
전체 시간: 234
