주요 콘텐츠로 건너뛰기
Protocol Slipstream EVO Propeller blades Replacement
필요한 것
  1. Protocol Slipstream EVO Propeller blades Replacement, Propeller blades: 1 단계, 이미지 1개 중 1개
    • With the drone flat on the ground identify which propeller you will be replacing.
  2. Protocol Slipstream EVO Propeller blades Replacement: 2 단계, 이미지 2개 중 1개 Protocol Slipstream EVO Propeller blades Replacement: 2 단계, 이미지 2개 중 2개
    • Using two fingers, place them on each side of the propellor near the middle.
    • Pull straight up with force. The propellor will feel as if it will not come off but do not be scared to use some muscle.
    • Warning: Pulling at an angle will result in bending the motor's needle.
  3. Protocol Slipstream EVO Propeller blades Replacement: 3 단계, 이미지 3개 중 1개 Protocol Slipstream EVO Propeller blades Replacement: 3 단계, 이미지 3개 중 2개 Protocol Slipstream EVO Propeller blades Replacement: 3 단계, 이미지 3개 중 3개
    • Checking the underside of the propeller there will be a letter which will correspond with each side of the drone
    • On the corner of the drone where the blade mounts onto the motor you will see which blade you should be using.
    • Warning: Failure to match the propeller blade to the right motor may result in the drone not flying.
    • Lining up the propeller blade with the needle, push down until the propeller is flushed.
결론
작성자
2다른 기여자 명과 함께
Michael Dang
회원 가입일: 04/10/17
301 평판
안내서 3개를 작성함
UW Tacoma, Team S3-G3, Liner Spring 2017 UW Tacoma, Team S3-G3, Liner Spring 2017 회원
UWT-LINER-S17S3G3
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 3
전체 시간: 603
