주요 콘텐츠로 건너뛰기
Protocol Slipstream WiFi Camera Replacement
필요한 것
  1. Protocol Slipstream WiFi Camera Replacement, Camera: 1 단계, 이미지 2개 중 1개 Protocol Slipstream WiFi Camera Replacement, Camera: 1 단계, 이미지 2개 중 2개
    • Remove the four 5.5 mm Phillips #00 screws that hold the lower canopy to the upper canopy.
    • Gently pull the lower canopy up and towards the back of the drone. The lower canopy will still be attached to the upper canopy by 3 wires. Just set the lower canopy aside and continue with the repair.
    • Be very careful when pulling the lower canopy apart from the upper canopy. There are 3 wires that will still be attached between the lower and upper canopies.
  2. Protocol Slipstream WiFi Camera Replacement: 2 단계, 이미지 2개 중 1개 Protocol Slipstream WiFi Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four 5.5 mm Phillips #00 screws that holds the battery tray to the lower canopy.
    • Once the four 5.5 mm Philips #00 screws are removed gently pull on the battery tray to separate it from the lower canopy.
  3. Protocol Slipstream WiFi Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Use a spudger to gently pry around the outside edge of the camera to remove the camera from its mounting hole.
    • Be careful when removing the camera from its mounting hole as there is a small ribbon wire that connects it to the computer.
    • The camera and computer assembly will now be free to move. Move the lower canopy out of the way for now.
  4. Protocol Slipstream WiFi Camera Replacement: 4 단계, 이미지 3개 중 1개 Protocol Slipstream WiFi Camera Replacement: 4 단계, 이미지 3개 중 2개 Protocol Slipstream WiFi Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Use the flat side of the spudger and push the 2 tabs on either side of the camera connection on the computer and push the tabs towards the front of the drone (away from the computer).
    • Make sure both tabs are all the way out otherwise the ribbon wire for the camera will not be free and you can damage the wire by pulling on it.
    • Now remove the camera ribbon wire from the camera connection on the computer.
결론
작성자
3다른 기여자 명과 함께
John Burkee
회원 가입일: 09/17/19
445 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 13
전체 시간: 310
