주요 콘텐츠로 건너뛰기
Protocol Vento Motor Replacement
필요한 것
  1. Protocol Vento Motor Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Grasp the tail end of the drone where the lip of the battery protrudes.
  2. Protocol Vento Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Pull away from the drone to remove the battery.
    • Do not attempt any repairs or replacements before removing the battery from the drone.
  3. Protocol Vento Motor Replacement, Propeller: 3 단계, 이미지 1개 중 1개
    • Place a prying tool under the base of the propeller.
  4. Protocol Vento Motor Replacement: 4 단계, 이미지 2개 중 1개 Protocol Vento Motor Replacement: 4 단계, 이미지 2개 중 2개
    • Use a moderate amount of force to pry the propeller out of its base. The propeller should pop off.
  5. Protocol Vento Motor Replacement, Motor: 5 단계, 이미지 1개 중 1개
    • Unscrew the 4.9mm Phillips #000 screw that is located at the end of the drone's arm.
  6. Protocol Vento Motor Replacement: 6 단계, 이미지 2개 중 1개 Protocol Vento Motor Replacement: 6 단계, 이미지 2개 중 2개
    • Hold the base of the arm while gently pulling the motor cover away from the arm.
    • Do not pull too hard because there are wires attaching the motor to the drone. Do not sever the wires.
  7. Protocol Vento Motor Replacement: 7 단계, 이미지 2개 중 1개 Protocol Vento Motor Replacement: 7 단계, 이미지 2개 중 2개
    • Gently pull the motor out from the plastic cover.
    • Do not squeeze or pull too hard, as to not damage the motor connection.
  8. Protocol Vento Motor Replacement: 8 단계, 이미지 2개 중 1개 Protocol Vento Motor Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • The motor’s blue and red wires are secured via a white clip. This clip is inserted into a slot in the drone’s leg.
    • Grasp the clip’s edges with a pair of tweezers and pull outward.
    • Do not pull directly on the wires, as to not separate the wires from the clip.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Maria Larcomb
회원 가입일: 02/15/18
926 평판
안내서 5개를 작성함
USF Tampa, Team S1-G2, Leahy Spring 2018 USF Tampa, Team S1-G2, Leahy Spring 2018 회원
USFT-LEAHY-S18S1G2
4 회원들
안내서 6개를 작성함
2가이드 댓글
Please send me motor description
suresh virji - 답글
send me protocol vento motor
suresh virji - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 5
전체 시간: 760
