소개
Whether you're experiencing a sudden drop in performance or your mouse has ceased to function altogether, troubleshooting and replacing the battery can often be the key to restoring your device to optimal functionality.
In this step-by-step guide, we'll walk you through accessing the battery compartment and safely replacing the battery in your Pulsar Xlite V2 Wireless mouse. After following this guide, your Pulsar Xlite V2 Wireless mouse should continue to deliver a smooth and reliable performance.
필요한 것
Disassembly is the first step, which requires something thin like a mini pry bar or even your fingernails, specifically to remove the lower mouse skate at the flat bottom side of the mouse.
The battery is located towards the lower end of the mouse in a rectangular housing, where the palm would usually rest above, along with wires connecting to its white 3-pin slot towards the opposite side of the battery location. Remove the connector, located in the second picture by the red circle, from its slot and the battery.
The new battery can now be attached in the opposite manner as the detached battery by connecting the 3-pin connector in its slot.
Now that you've successfully replaced the battery, enjoy the renewed efficiency and responsiveness of your Pulsar Xlite V2 Wireless mouse. Happy computing!
다른 한 분이 해당 안내서를 완성하였습니다.
