주요 콘텐츠로 건너뛰기
Pulsar Xlite V2 Wireless Battery Replacement
필요한 것
  1. Pulsar Xlite V2 Wireless Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Pulsar Xlite V2 Wireless Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Disassembly is the first step, which requires something thin like a mini pry bar or even your fingernails, to remove the lower mouse skate on the flat underside of the mouse.
  2. Pulsar Xlite V2 Wireless Battery Replacement, Unscrew the underside: 2 단계, 이미지 1개 중 1개
    • After removing the mouse skate, use a Phillips screwdriver to unscrew two screws and detach the bottom layer of the mouse.
  3. Pulsar Xlite V2 Wireless Battery Replacement, Separate the bottom layer: 3 단계, 이미지 3개 중 1개 Pulsar Xlite V2 Wireless Battery Replacement, Separate the bottom layer: 3 단계, 이미지 3개 중 2개 Pulsar Xlite V2 Wireless Battery Replacement, Separate the bottom layer: 3 단계, 이미지 3개 중 3개
    • To separate the bottom and top layer, begin lifting the bottom half of the mouse.
    • Next, apply some pressure by pushing the top layer towards the hinges seen in the second picture. Then, the entire top layer can be lifted off.
  4. Pulsar Xlite V2 Wireless Battery Replacement, Disconnect the old battery: 4 단계, 이미지 3개 중 1개 Pulsar Xlite V2 Wireless Battery Replacement, Disconnect the old battery: 4 단계, 이미지 3개 중 2개 Pulsar Xlite V2 Wireless Battery Replacement, Disconnect the old battery: 4 단계, 이미지 3개 중 3개
    • The battery is located towards the lower end of the mouse in a rectangular housing, where the palm would usually rest above, along with wires connecting to its white 3-pin slot towards the opposite side of the battery location.
    • Remove the connector from its slot and the battery.
    • The new battery can now be attached in the opposite manner by connecting the 3-pin connector in its slot.
    • The connector pin can initally be tightly secured meaning you might require slightly more force than you expect to detach the pin. Be wary of the surrounding parts near the pin as to not damage the rest of the mouse.
    • Reassembly is simply steps 2 through 4 in reverse order.
    • However, when finishing with step 2, the bottom mouse skate can be easily applied without the user of fingernails or the mini pry bar.
결론
Now that you've successfully replaced the battery, enjoy the renewed efficiency and responsiveness of your Pulsar Xlite V2 Wireless mouse. Happy computing!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Darrin Du
회원 가입일: 10/24/23
148 평판
안내서 1개를 작성함
CSU Los Angeles, Team 12-3, Ribeiro Fall 2023 CSU Los Angeles, Team 12-3, Ribeiro Fall 2023 회원
CSULA-RIBEIRO-F23S12G3
2 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 72
전체 시간: 2,983
