주요 콘텐츠로 건너뛰기
Purple SmartVP Camera Replacement
필요한 것
  1. Purple SmartVP Camera Replacement, Camera: 1 단계, 이미지 1/2 Purple SmartVP Camera Replacement, Camera: 1 단계, 이미지 2/2
    • Remove the top bar by removing the 5cm hex T10 screws on the back of the device as shown. Then gently pull off the top bar from the main component.
  2. Purple SmartVP Camera Replacement: 2 단계, 이미지 1/2 Purple SmartVP Camera Replacement: 2 단계, 이미지 2/2
    • Remove the 1.2 cm hex T9 screws and gently open up the device.
  3. Purple SmartVP Camera Replacement: 3 단계, 이미지 1/2 Purple SmartVP Camera Replacement: 3 단계, 이미지 2/2
    • Detach the camera cover from the motherboard. Be very careful to not damage any of the components on the motherboard.
  4. Purple SmartVP Camera Replacement: 4 단계, 이미지 1/2 Purple SmartVP Camera Replacement: 4 단계, 이미지 2/2
    • Use a plastic spudger to push the black sliding cable connector away from the white bracket.
  5. Purple SmartVP Camera Replacement: 5 단계, 이미지 1/1
    • Gently remove the ribbon cable from the connector.
결론
Brian Maulucci
회원 가입일: 09/10/18
579 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 212
