주요 콘텐츠로 건너뛰기
Putting On A Transparent Shell On Flipper Zero
필요한 것
  1. Putting On A Transparent Shell On Flipper Zero, Take Out The SD Card: 1 단계, 이미지 1개 중 1개
    • An Easy Way To Get The SD Card Out Is To Grip It With Your Fingernails.
  2. Putting On A Transparent Shell On Flipper Zero, Remove The 4 PH0 Screws On The Back: 2 단계, 이미지 3개 중 1개 Putting On A Transparent Shell On Flipper Zero, Remove The 4 PH0 Screws On The Back: 2 단계, 이미지 3개 중 2개 Putting On A Transparent Shell On Flipper Zero, Remove The 4 PH0 Screws On The Back: 2 단계, 이미지 3개 중 3개
    • Use A PH0 Screwdriver To Open/Remove The Back Part Of The Shell.
    • Be Careful, The Screws Strip Easily. One Way To Combat This Is To Press Down On The Screw While Unscrewing It.
  3. Putting On A Transparent Shell On Flipper Zero, Taking Off The Back Shell: 3 단계, 이미지 3개 중 1개 Putting On A Transparent Shell On Flipper Zero, Taking Off The Back Shell: 3 단계, 이미지 3개 중 2개 Putting On A Transparent Shell On Flipper Zero, Taking Off The Back Shell: 3 단계, 이미지 3개 중 3개
    • Using Your Fingernail, Spudger, Guitar Pick, Or Any Other Prying Tool, Take Off The Back Shell.
  4. Putting On A Transparent Shell On Flipper Zero, Take Out The Internals: 4 단계, 이미지 3개 중 1개 Putting On A Transparent Shell On Flipper Zero, Take Out The Internals: 4 단계, 이미지 3개 중 2개 Putting On A Transparent Shell On Flipper Zero, Take Out The Internals: 4 단계, 이미지 3개 중 3개
    • Using Your PH0 Screwdriver Unscrew The Two Short Screws Holding The Internals Down To The Shell.
    • Be Careful With The iButton Pins, They Break Off Very Easily.
  5. Putting On A Transparent Shell On Flipper Zero, Transfer The Flipper's Internals To The New Shell: 5 단계, 이미지 2개 중 1개 Putting On A Transparent Shell On Flipper Zero, Transfer The Flipper's Internals To The New Shell: 5 단계, 이미지 2개 중 2개
    • Put Your Flipper's Internals Into The New Shell.
    • Screw The Three Short Screws Back Into Place.
    • Do Not Make The Screws Too Tight As The Threads On The New Transparent Board Will Strip Because It Is 3D Printed.
  6. Putting On A Transparent Shell On Flipper Zero, Take The NFC Board Off The Back Shell: 6 단계, 이미지 2개 중 1개 Putting On A Transparent Shell On Flipper Zero, Take The NFC Board Off The Back Shell: 6 단계, 이미지 2개 중 2개
    • Using Your, Spudger, Guitar Pick, Flathead Screwdriver, Or Any Other Prying Tool, Take Off The NFC Board
    • Do Not Use Your Fingernails To Take Off The NFC Board!
  7. Putting On A Transparent Shell On Flipper Zero, Put The NFC Board Onto The New Transparent Back Shell: 7 단계, 이미지 1개 중 1개
    • The NFC Board Should Look Like How It Is In The Picture, If It Doesn't Look Like The Picture Reapply The NFC Board.
  8. Putting On A Transparent Shell On Flipper Zero, Combine The Two Shells: 8 단계, 이미지 2개 중 1개 Putting On A Transparent Shell On Flipper Zero, Combine The Two Shells: 8 단계, 이미지 2개 중 2개
    • Put The Two Shells Together And Then Insert The Four Long Screws Into The Screw Holes And Tighten Them.
  9. Putting On A Transparent Shell On Flipper Zero, YA DONE!: 9 단계, 이미지 2개 중 1개 Putting On A Transparent Shell On Flipper Zero, YA DONE!: 9 단계, 이미지 2개 중 2개
    • You Have Just Assembled Yourself A Transparent Flipper Zero, Nice Work!
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kaeden
회원 가입일: 06/02/24
337 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 27
지난 30일: 126
전체 시간: 1,525
