주요 콘텐츠로 건너뛰기
QFX IT-437 Camera Assembly Replacement
필요한 것
  1. QFX IT-437 Camera Assembly Replacement, Camera Assembly: 1 단계, 이미지 1/1
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Camera Assembly Replacement: 2 단계, 이미지 1/2 QFX IT-437 Camera Assembly Replacement: 2 단계, 이미지 2/2
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Camera Assembly Replacement: 3 단계, 이미지 1/1
    • Use the spudger to unhinge the camera from its socket.
  4. QFX IT-437 Camera Assembly Replacement: 4 단계, 이미지 1/1
    • Use the plastic opening pick and the Phillips screwdriver to remove the camera from its soldering on the motherboard, and set it aside to be replaced.
결론
Douglas
회원 가입일: 01/28/15
482 평판
안내서 4개 작성하였습니다
Pasco Hernando, Team 5-2, Prince Winter 2015 Pasco Hernando, Team 5-2, Prince Winter 2015 회원
PHSC-PRINCE-W15S5G2
6 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 106
