주요 콘텐츠로 건너뛰기
QFX IT-437 Motherboard Replacement
필요한 것
  1. QFX IT-437 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Motherboard Replacement: 2 단계, 이미지 1/2 QFX IT-437 Motherboard Replacement: 2 단계, 이미지 2/2
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Motherboard Replacement: 3 단계, 이미지 1/1
    • In order to unseat the motherboard, use the Phillips PH00 screw driver bit to remove the three 1.2mm x 3mm screws.
  4. QFX IT-437 Motherboard Replacement: 4 단계, 이미지 1/1
    • Once the motherboard is loose, remove the tape above the SD card slot using an iFixit opening pick.
    • Be careful not to rip or damage the tape or else new tape will have to be used for the new motherboard.
  5. QFX IT-437 Motherboard Replacement: 5 단계, 이미지 1/1
    • Use the spudger to remove the ribbon.
    • Avoid using too much force here or else the ribbon can be ripped.
  6. QFX IT-437 Motherboard Replacement: 6 단계, 이미지 1/1
    • Use the spudger in the top corner of the tablet and lift the camera up.
  7. QFX IT-437 Motherboard Replacement: 7 단계, 이미지 1/1
    • Lift the tape over the wires that are holding them to the tablet insulation.
  8. QFX IT-437 Motherboard Replacement: 8 단계, 이미지 1/1
    • Pull out the motherboard and set it aside.
    • The wires must be soldered back on to the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Douglas
회원 가입일: 01/28/15
482 평판
안내서 4개 작성하였습니다
Pasco Hernando, Team 5-2, Prince Winter 2015 Pasco Hernando, Team 5-2, Prince Winter 2015 회원
PHSC-PRINCE-W15S5G2
6 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 229
