주요 콘텐츠로 건너뛰기
QFX IT-437 Speaker Replacement
필요한 것
  1. QFX IT-437 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Begin the tear down with a Phillips PH00 screwdriver.
    • Remove two 1.2mm x 3mm Phillips screws.
  2. QFX IT-437 Speaker Replacement: 2 단계, 이미지 1/2 QFX IT-437 Speaker Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry open the case.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires that connect to the speaker.
  3. QFX IT-437 Speaker Replacement: 3 단계, 이미지 1/1
    • Carefully remove the tape over the wires connecting the speaker to the motherboard.
  4. QFX IT-437 Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the speaker unit from the tablet and set aside.
결론
Douglas
회원 가입일: 01/28/15
482 평판
안내서 4개 작성하였습니다
Pasco Hernando, Team 5-2, Prince Winter 2015 Pasco Hernando, Team 5-2, Prince Winter 2015 회원
PHSC-PRINCE-W15S5G2
6 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 824
