주요 콘텐츠로 건너뛰기
Qanba Crystal Joystick and Buttons Replacement
필요한 것
  1. Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: 1 단계, 이미지 3개 중 1개 Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: 1 단계, 이미지 3개 중 2개 Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: 1 단계, 이미지 3개 중 3개
    • Use the Phillips #1 screwdriver to remove the eight 20 mm screws.
    • Remove the metal plate to gain access to the internals of the device.
  2. Qanba Crystal Joystick and Buttons Replacement: 2 단계, 이미지 3개 중 1개 Qanba Crystal Joystick and Buttons Replacement: 2 단계, 이미지 3개 중 2개 Qanba Crystal Joystick and Buttons Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Taking a picture or marking cables with masking tape is advised as it will help with the reassembly process.
    • Each button has three cables, unplug these from each one.
    • The joystick has two cables, unplug both of these.
    • The use of ESD safe tweezers may assist with unplugging the cables.
  3. Qanba Crystal Joystick and Buttons Replacement: 3 단계, 이미지 3개 중 1개 Qanba Crystal Joystick and Buttons Replacement: 3 단계, 이미지 3개 중 2개 Qanba Crystal Joystick and Buttons Replacement: 3 단계, 이미지 3개 중 3개
    • Use the Phillips #1 screwdriver to remove the four 10 mm screws.
    • Use a flathead screwdriver to hold the screw in place.
    • Twist off the ball top of the joystick while holding the screw in place with a screwdriver.
    • Remove the joystick and all of it's components.
  4. Qanba Crystal Joystick and Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Press in the tabs on the top and bottom of the buttons to remove them.
    • The outline of the buttons are sharp, do exercise caution with the removal of the buttons.
  5. Qanba Crystal Joystick and Buttons Replacement: 5 단계, 이미지 3개 중 1개 Qanba Crystal Joystick and Buttons Replacement: 5 단계, 이미지 3개 중 2개 Qanba Crystal Joystick and Buttons Replacement: 5 단계, 이미지 3개 중 3개
    • Flip the controller over.
    • Peel the six shiny stickers and their epoxy glue off of the controller.
    • Remove the six Phillips #1 screws underneath the sticker covers.
    • Remove the acrylic panel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kevin Vu
회원 가입일: 06/29/21
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 64
지난 30일: 258
전체 시간: 5,109
