주요 콘텐츠로 건너뛰기
Qualcomm QCP-2760 Keypad Replacement
필요한 것
  1. Qualcomm QCP-2760 Keypad Replacement, Battery: 1 단계, 이미지 1/1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Qualcomm QCP-2760 Keypad Replacement, Rear Backing: 2 단계, 이미지 1/2 Qualcomm QCP-2760 Keypad Replacement, Rear Backing: 2 단계, 이미지 2/2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
  3. Qualcomm QCP-2760 Keypad Replacement, Motherboard: 3 단계, 이미지 1/1
    • Locate the four metal clips holding the motherboard onto the phone.
    • Pull the clips away from the motherboard while lifting the motherboard out of the case.
    • The motherboard is attached to the case by a fragile cable, do not apply any stress to the cable.
  4. Qualcomm QCP-2760 Keypad Replacement: 4 단계, 이미지 1/2 Qualcomm QCP-2760 Keypad Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Place the motherboard down so that the screen is facing up.
    • Grab the small brown connector plug at the sides with a fingernail or tweezers and flip it up.
    • Locate, but do not disconnect, the four screen clips.
  5. Qualcomm QCP-2760 Keypad Replacement: 5 단계, 이미지 1/2 Qualcomm QCP-2760 Keypad Replacement: 5 단계, 이미지 2/2
    • Flip the motherboard over so that the screen is facing down.
    • Again, be careful not to put stress on the speaker cable.
  6. Qualcomm QCP-2760 Keypad Replacement, Keypad: 6 단계, 이미지 1/1
    • Remove keypad circuit board by lifting up circuit board while pulling clip.
    • Remove rubber keypad
    • Insert new rubber keypad.
결론
Colin Packard
회원 가입일: 09/30/14
101 평판
안내서 1개 작성함
Ohio State, Team 1-4, Buehl Fall 2014 Ohio State, Team 1-4, Buehl Fall 2014 회원
OSU-BUEHL-F14S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 193
