주요 콘텐츠로 건너뛰기
Qualcomm Snapdragon 800 Mobile Development Antenna Replacement
필요한 것
  1. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Battery: 1 단계, 이미지 1/2 Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Battery: 1 단계, 이미지 2/2
    • Locate your device.
    • Flip device onto its back.
  2. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: 2 단계, 이미지 1/1
    • Remove the tablet's back cover.
  3. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: 3 단계, 이미지 1/1
    • Locate the battery and remove it.
    • If you wish to replace the battery you can do so here.
  4. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Back Panel: 4 단계, 이미지 1/2 Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Back Panel: 4 단계, 이미지 2/2
    • Use the Phillips PH1 screwdriver to unscrew the five 4x2.5mm screws that hold the back cover.
  5. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: 5 단계, 이미지 1/1
    • Pop out the back cover.
  6. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Antennas: 6 단계, 이미지 1/1
    • After removing the panel and the battery, your tablet should look like this.
  7. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: 7 단계, 이미지 1/2 Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: 7 단계, 이미지 2/2
    • Locate the tablet's antennas.
    • Remove the two 3x2.5mm screws holding them down.
  8. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: 8 단계, 이미지 1/1
    • Remove antennas and replace them as needed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Omar
회원 가입일: 09/25/17
261 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 206
