주요 콘텐츠로 건너뛰기
Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement
필요한 것
  1. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Locate your device.
    • Flip device onto its back.
  2. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the tablet's back cover.
  3. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 3 단계, 이미지 1/1
    • Locate the battery and remove it.
    • If you wish to replace the battery you can do so here.
  4. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Back Panel: 4 단계, 이미지 1/2 Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Back Panel: 4 단계, 이미지 2/2
    • Use the Phillips PH1 screwdriver to unscrew the five 4x2.5mm screws that hold the back cover.
  5. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 5 단계, 이미지 1/1
    • Pop out the back cover.
  6. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Motherboard: 6 단계, 이미지 1/3 Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Motherboard: 6 단계, 이미지 2/3 Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Motherboard: 6 단계, 이미지 3/3
    • Start by disconnecting the cables attached to the motherboard
    • use the spudger to lift the connectors vertically off. They should pop off with relative ease
    • The last connector has a yellow tab. Pull up on the tab until the small metal catch lifts up. Then pull straight back to remove the connector from its socket.
  7. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 7 단계, 이미지 1/1
    • Using the Phillips PH1, remove all 6 of the 3x2.5mm screws (circled in red) holding the motherboard in place.
  8. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 8 단계, 이미지 1/1
    • Using the spudger lift the motherboard out of the tablet frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jason
회원 가입일: 09/25/17
149 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 491
