주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Quantum Axis A23 Camera Replacement
필요한 것
  1. Quantum Axis A23 Camera Replacement, Removing the Case: 1 단계, 이미지 1개 중 1개
    • Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
    • Be careful not to crack front screen in the process.
  2. Quantum Axis A23 Camera Replacement, Detaching the Camera from the Motherboard: 2 단계, 이미지 1개 중 1개
    • Use small needle nose pliers to carefully remove the yellow ribbon attached to the motherboard.
  3. Quantum Axis A23 Camera Replacement, Detaching the Camera from the Back of the Screen: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to remove the black tape holding the camera down.
  4. Quantum Axis A23 Camera Replacement, Attaching New Ribbon to Motherboard Slot: 4 단계, 이미지 1개 중 1개
    • Slot the new dual camera ribbon into the motherboard.
  5. Quantum Axis A23 Camera Replacement, Attach New Dual Cameras to Screen: 5 단계, 이미지 1개 중 1개
    • Attach dual cameras to the back of the screen with the black tape. Align the cameras with the designated hole in the case.
    • Fold over the camera piece so the camera are on top of each other with lenses facing out and the top as the rear.
결론
Snap the rear case back on (carefully aligning the back camera with the camera hole on the case) to finish this repair.
작성자
4다른 기여자 명과 함께
Randy Janz
회원 가입일: 01/15/15
101 평판
안내서 1개를 작성함
USF Tampa, Team 1-5, Tanski Winter 2015 USF Tampa, Team 1-5, Tanski Winter 2015 회원
USFT-TANSKI-W15S1G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 323
