주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Quantum Axis A23 Motherboard Replacement
필요한 것
  1. Quantum Axis A23 Motherboard  Replacement, Removing the Case: 1 단계, 이미지 1개 중 1개
    • Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
    • Be careful not to crack front screen in the process.
  2. Quantum Axis A23 Motherboard  Replacement, Unscrewing the Motherboard: 2 단계, 이미지 1개 중 1개
    • Remove all three screws holding down the motherboard, using the Phillips #00 Precision Screwdriver and slot in the Phillips Head PH #0.
  3. Quantum Axis A23 Motherboard  Replacement: 3 단계, 이미지 1개 중 1개
    • Using the small needle nose pliers, carefully remove the small yellow ribbons that are attached to the motherboard.
  4. Quantum Axis A23 Motherboard  Replacement: 4 단계, 이미지 2개 중 1개 Quantum Axis A23 Motherboard  Replacement: 4 단계, 이미지 2개 중 2개
    • Cut the red and black wires that connect the battery, screen, camera, and speakers to the motherboard.
  5. Quantum Axis A23 Motherboard  Replacement, Screwing the Motherboard Back On: 5 단계, 이미지 2개 중 1개 Quantum Axis A23 Motherboard  Replacement, Screwing the Motherboard Back On: 5 단계, 이미지 2개 중 2개
    • Take the the new motherboard and screw it in with the screws used on the previous motherboard, starting with the top right and bottom left corners.
    • Screw on the top left corner last
  6. Quantum Axis A23 Motherboard  Replacement: 6 단계, 이미지 1개 중 1개
    • Strip both the red and black wires in the middle with a wire stripper/cutter tool. Do this for all wires that were cut, as well as for the wires on your new motherboard.
  7. Quantum Axis A23 Motherboard  Replacement: 7 단계, 이미지 1개 중 1개
    • Take the red wire from the specified part and attach to the red wire on the motherboard, then twist the two ends together and wrap in electrical tape. Repeat this step for the black wires.
    • Do this for every part that was attached to the motherboard.
결론
Snap the rear case back on to finish this repair.
작성자
6다른 기여자 명과 함께
Nicole
회원 가입일: 01/12/15
407 평판
안내서 4개를 작성함
USF Tampa, Team 1-5, Tanski Winter 2015 USF Tampa, Team 1-5, Tanski Winter 2015 회원
USFT-TANSKI-W15S1G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 38
전체 시간: 545
