주요 콘텐츠로 건너뛰기
Quantum View 10.1 Battery Replacement
필요한 것
  1. Quantum View 10.1 Battery Replacement, Open Quantum View case: 1 단계, 이미지 1/1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 Battery Replacement, Removing the electrical tape and magnets.: 2 단계, 이미지 1/2 Quantum View 10.1 Battery Replacement, Removing the electrical tape and magnets.: 2 단계, 이미지 2/2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 Battery Replacement, Unhooking the battery: 3 단계, 이미지 1/2 Quantum View 10.1 Battery Replacement, Unhooking the battery: 3 단계, 이미지 2/2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
결론
stephen Munchinsky
회원 가입일: 04/01/17
786 평판
안내서 7개 작성하였습니다
Gateway Community College Team 1 BPC270 36301 Gateway Community College Team 1 BPC270 36301 회원
Community
4 회원들
안내서 7개 작성하였습니다
댓글 3개
How do I find a replacement battery?
Chris Clayton - 답글
Seems finding the right battery is a problem
Chris Clayton - 답글
where can I find a replacement battery and screen for this i only have the motherboard lying around and i really want to repair it so i can access old data
aabel joby - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 17
전체 시간: 847
