주요 콘텐츠로 건너뛰기
Quantum View 10.1 Motherboard Replacement
필요한 것
  1. Quantum View 10.1 Motherboard Replacement, Open Quantum View case: 1 단계, 이미지 1/1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 Motherboard Replacement, Removing the electrical tape and magnets.: 2 단계, 이미지 1/2 Quantum View 10.1 Motherboard Replacement, Removing the electrical tape and magnets.: 2 단계, 이미지 2/2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 Motherboard Replacement, Unhooking the battery: 3 단계, 이미지 1/2 Quantum View 10.1 Motherboard Replacement, Unhooking the battery: 3 단계, 이미지 2/2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
  4. Quantum View 10.1 Motherboard Replacement, Disconnect Cables: 4 단계, 이미지 1/3 Quantum View 10.1 Motherboard Replacement, Disconnect Cables: 4 단계, 이미지 2/3 Quantum View 10.1 Motherboard Replacement, Disconnect Cables: 4 단계, 이미지 3/3
    • Remove silver protective sticker and set to the side.
    • Ensure all ribbon cables and other connectors are disconnected from mother board.
  5. Quantum View 10.1 Motherboard Replacement, Remove Screws: 5 단계, 이미지 1/2 Quantum View 10.1 Motherboard Replacement, Remove Screws: 5 단계, 이미지 2/2
    • There are 4 small screws connecting the motherboard to the frame of the device. Take a PH00 bit screw driver to remove these screws.
  6. Quantum View 10.1 Motherboard Replacement, Remove Motherboard: 6 단계, 이미지 1/1
    • Gently and carefully lift motherboard straight up from frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
stephen Munchinsky
회원 가입일: 04/01/17
786 평판
안내서 7개 작성하였습니다
Gateway Community College Team 1 BPC270 36301 Gateway Community College Team 1 BPC270 36301 회원
Community
4 회원들
안내서 7개 작성하였습니다
댓글 4개
tell me which battery is suitable ?
Иван Шульга - 답글
Hi
I would like to request for my tablet bios.bin EM_i8211 V6.1 (this code on board )
My tablet is fail bios
Please help me,
Ye Yint Aung - 답글
Hi
My tablet bois missing when it was updating …
MB model is EM_i8211 V6.1
Please help me for find bios file …
tnx alot …
p30emaile@yahoo.com
Nima khalaji - 답글
Hello, I have a CSL Panhter Tab 10 v2 which has the same mainboard. Because my bios is defective, it won't start anymore! My request, could you read the BIOS and attach the ROM.bin to a PM or send me a link. there is simply nothing left to find I would be very grateful
Felix Klein - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 29
전체 시간: 1,250
