주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Quasar Microwave Capacitor Replacement
필요한 것
    1. Quasar Microwave Capacitor Replacement, Disassembling Quasar Microwave Outer Cover: 1 단계, 이미지 1개 중 1개
      • Disconnect the power supply cord from the outlet.
      댓글 쓰기
    2. Quasar Microwave Capacitor Replacement: 2 단계, 이미지 2개 중 1개 Quasar Microwave Capacitor Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the eight screws holding the wood-patterned cover to the microwave frame.
      • The first four screws are located on either side of the microwave front.
      댓글 쓰기
    3. Quasar Microwave Capacitor Replacement: 3 단계, 이미지 2개 중 1개 Quasar Microwave Capacitor Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the additional four screws securing the wood-paneled case to the microwave frame.
      댓글 쓰기
    4. Quasar Microwave Capacitor Replacement: 4 단계, 이미지 3개 중 1개 Quasar Microwave Capacitor Replacement: 4 단계, 이미지 3개 중 2개 Quasar Microwave Capacitor Replacement: 4 단계, 이미지 3개 중 3개
      • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
      • Lift the case upward slowly until the case is free of the microwave.
      댓글 쓰기
    1. Quasar Microwave Capacitor Replacement, Capacitor: 5 단계, 이미지 2개 중 1개 Quasar Microwave Capacitor Replacement, Capacitor: 5 단계, 이미지 2개 중 2개
      • Old electronics collect dust, no matter if they are in active use or being stored. It is recommended to clear out some of the dust prior to affecting any complicated repairs. Use compressed air, and wear a dust mask and goggles. Always use precaution when working with old electronics.
      • The capacitor stores a small amount of electrical energy. Discharge capacitor by placing a screw driver across the terminals. Use a screwdriver with a non-metallic handle and a shaft that is longer than 4” (10.75mm) Touch the metal shaft of the screwdriver simultaneously to both metal terminals of the capacitor. There should be a spark.
      • If the capacitor sparks, you can stop reading here. The spark indicates that the capacitor is working properly. If the capacitor does not spark, read on to Step 6.
      댓글 쓰기
    2. Quasar Microwave Capacitor Replacement: 6 단계, 이미지 1개 중 1개
      • Place the multimeter on resistance mode and test the resistance of the capacitor.
      • If the resistance increases/decreases, the capacitor is working fine. If the resistance of the capacitor reads 0 or over several kilo ohms, the capacitor needs to be replaced.
      댓글 쓰기
    3. Quasar Microwave Capacitor Replacement: 7 단계, 이미지 3개 중 1개 Quasar Microwave Capacitor Replacement: 7 단계, 이미지 3개 중 2개 Quasar Microwave Capacitor Replacement: 7 단계, 이미지 3개 중 3개
      • Tip the microwave back so it is lying face up. This allows access to the screws beneath the transformer.
      댓글 쓰기
    4. Quasar Microwave Capacitor Replacement: 8 단계, 이미지 2개 중 1개 Quasar Microwave Capacitor Replacement: 8 단계, 이미지 2개 중 2개
      • Locate the transformer. The capacitor cannot be removed without removing the transformer first.
      • Locate and unhook all wires connecting the transformer to the rest of the microwave.
      • Take note of where each wire connects before disconnecting. Wiring a microwave incorrectly can cause serious damage.
      댓글 쓰기
    5. Quasar Microwave Capacitor Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the four exterior screws securing the transformer to the microwave frame.
      댓글 쓰기
    6. Quasar Microwave Capacitor Replacement: 10 단계, 이미지 3개 중 1개 Quasar Microwave Capacitor Replacement: 10 단계, 이미지 3개 중 2개 Quasar Microwave Capacitor Replacement: 10 단계, 이미지 3개 중 3개
      • Remove the transformer.
      댓글 쓰기
    7. Quasar Microwave Capacitor Replacement: 11 단계, 이미지 2개 중 1개 Quasar Microwave Capacitor Replacement: 11 단계, 이미지 2개 중 2개
      • The metal band locking the capacitor in place can now be accessed. Locate and remove the screw securing the the metal band.
      • Lift the metal band off the capacitor.
      댓글 쓰기
    8. Quasar Microwave Capacitor Replacement: 12 단계, 이미지 3개 중 1개 Quasar Microwave Capacitor Replacement: 12 단계, 이미지 3개 중 2개 Quasar Microwave Capacitor Replacement: 12 단계, 이미지 3개 중 3개
      • Remove the capacitor.
      댓글 쓰기
    9. Quasar Microwave Capacitor Replacement: 13 단계, 이미지 1개 중 1개
      • You can now install a replacement capacitor.
      • Repeat all steps in reverse order to install a capacitor in a Quasar Microwave MQ7774XW (1984).
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Michael
회원 가입일: 09/26/12
237 평판
안내서 2개를 작성함
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G12
3 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 65
전체 시간: 7,592
