주요 콘텐츠로 건너뛰기
Quiksilver The Fifty50 Analog Battery Replacement
필요한 것
  1. Quiksilver The Fifty50 Analog Battery Replacement, Strap: 1 단계, 이미지 1/2 Quiksilver The Fifty50 Analog Battery Replacement, Strap: 1 단계, 이미지 2/2
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Analog Battery Replacement: 2 단계, 이미지 1/2 Quiksilver The Fifty50 Analog Battery Replacement: 2 단계, 이미지 2/2
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Analog Battery Replacement, Back Panel: 3 단계, 이미지 1/2 Quiksilver The Fifty50 Analog Battery Replacement, Back Panel: 3 단계, 이미지 2/2
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Analog Battery Replacement: 4 단계, 이미지 1/1
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
  5. Quiksilver The Fifty50 Analog Battery Replacement, Analog Battery: 5 단계, 이미지 1/2 Quiksilver The Fifty50 Analog Battery Replacement, Analog Battery: 5 단계, 이미지 2/2
    • Carefully lift the white plastic circular out of the watch.
  6. Quiksilver The Fifty50 Analog Battery Replacement: 6 단계, 이미지 1/3 Quiksilver The Fifty50 Analog Battery Replacement: 6 단계, 이미지 2/3 Quiksilver The Fifty50 Analog Battery Replacement: 6 단계, 이미지 3/3
    • Remove the four 1.1 mm screws located on the metallic holder using the Phillips #00 screwdriver.
  7. Quiksilver The Fifty50 Analog Battery Replacement: 7 단계, 이미지 1/3 Quiksilver The Fifty50 Analog Battery Replacement: 7 단계, 이미지 2/3 Quiksilver The Fifty50 Analog Battery Replacement: 7 단계, 이미지 3/3
    • Remove the large circular Analog battery.
결론
Sue Giske
회원 가입일: 07/16/19
622 평판
안내서 5개 작성하였습니다
UW Tacoma, Team S1-G4, Liner Summer 2019 UW Tacoma, Team S1-G4, Liner Summer 2019 회원
UWT-LINER-SU19S1G4
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 18
전체 시간: 662
