주요 콘텐츠로 건너뛰기
RAVPower FileHub Travel Router AC750 Disassembly
필요한 것
  1. RAVPower FileHub Travel Router AC750 Disassembly, Bring your device and make sure everything is off and disconnected: 1 단계, 이미지 2개 중 1개 RAVPower FileHub Travel Router AC750 Disassembly, Bring your device and make sure everything is off and disconnected: 1 단계, 이미지 2개 중 2개
    • Brand New RAVPower FileHub Travel Router AC750
    • No screws what so ever, all is tightly sealed.
  2. RAVPower FileHub Travel Router AC750 Disassembly, Open the rubber seal and shimmy on the case surrounding the connectors: 2 단계, 이미지 3개 중 1개 RAVPower FileHub Travel Router AC750 Disassembly, Open the rubber seal and shimmy on the case surrounding the connectors: 2 단계, 이미지 3개 중 2개 RAVPower FileHub Travel Router AC750 Disassembly, Open the rubber seal and shimmy on the case surrounding the connectors: 2 단계, 이미지 3개 중 3개
    • Open the rubber seal and begin, very carefully, opening the surroundings.
    • 'Note that there is an adhesive on the other side holding the case' among other elements like: battery (most prominent), the WiFi antennas (is the 2.4Ghz & 5Ghz on the top of the case) and the lights circuit of the device.
  3. RAVPower FileHub Travel Router AC750 Disassembly, Pull the case a bit, be careful not to break the top parts: 3 단계, 이미지 3개 중 1개 RAVPower FileHub Travel Router AC750 Disassembly, Pull the case a bit, be careful not to break the top parts: 3 단계, 이미지 3개 중 2개 RAVPower FileHub Travel Router AC750 Disassembly, Pull the case a bit, be careful not to break the top parts: 3 단계, 이미지 3개 중 3개
    • Again, open carefully because of the attached items to the top case. In this picture a accidentally broke the connection in the 5Ghz WiFi Antenna.
  4. RAVPower FileHub Travel Router AC750 Disassembly, It's open! congrats!: 4 단계, 이미지 3개 중 1개 RAVPower FileHub Travel Router AC750 Disassembly, It's open! congrats!: 4 단계, 이미지 3개 중 2개 RAVPower FileHub Travel Router AC750 Disassembly, It's open! congrats!: 4 단계, 이미지 3개 중 3개
    • Insert wisdom here.
결론
작성자
2다른 기여자 명과 함께
Andres Urena
회원 가입일: 12/01/20
139 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 1,242
