주요 콘텐츠로 건너뛰기
RCA 10 Viking Pro RCT6K03W13 Antenna Replacement
필요한 것
  1. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: 1 단계, 이미지 1/3 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: 1 단계, 이미지 2/3 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: 1 단계, 이미지 3/3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: 2 단계, 이미지 1/2 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: 2 단계, 이미지 2/2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: 3 단계, 이미지 1/1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: 4 단계, 이미지 1/2 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: 4 단계, 이미지 2/2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Antenna: 5 단계, 이미지 1/1
    • Identify the grey wire on the right side of the device.
  6. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: 6 단계, 이미지 1/1
    • Remove the orange ribbon cable over the wire.
  7. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: 7 단계, 이미지 1/1
    • Remove the antenna using a soldering iron.
결론
Ryan Wickett
회원 가입일: 10/25/19
632 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G8
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Does anyone know where I can buy a new antenna for this device?
DIY_Human - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 8
전체 시간: 397
