소개
If your screen is cracked or has dead pixels and is in need of replacement, this guide explains how to remove the screen from the TV.
필요한 것
Lay the TV flat with the screen facing down.
Remove the four, 12mm Phillips #2 screws from the back of the TV stand. Support the TV from underneath as you remove the screws, so the bottom does not fall on the table.
Remove the stand by lifting it away from the TV's backing.
Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing.
Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
While holding the screen down, pull the back panel up slowly, ensuring that you do not forcibly disconnect the remaining ribbon cable.
Position the television to where the back panel is resting on the table and the screen is vertical.
Peel the tape covering the ribbon cable horizontally.
Remove the four, 12mm Phillips #2 screws from the outer edge of the back of the screen panel.
Remove the two, 5mm Phillips #2 screws from the metal bracket attached to the horizontal side of the TV and take the bracket off.
Repeat this process on the other side of the TV to completely isolate the screen.
다른 2명이 해당 안내서를 완성하였습니다.
