소개
There are two speakers situated on the lower half of the TV. You may choose to upgrade your speakers or these speakers may malfunction and need to be replaced. This guide will teach you how to do so.
필요한 것
Lay the TV flat with the screen facing down.
Remove the four, 12mm Phillips #2 screws from the back of the TV stand. Support the TV from underneath as you remove the screws, so the bottom does not fall on the table.
Remove the stand by lifting it away from the TV's backing.
Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing.
Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
While holding the screen down, pull the back panel up slowly, ensuring that you do not forcibly disconnect the remaining ribbon cable.
Position the television to where the back panel is resting on the table and the screen is vertical.
Peel the tape covering the ribbon cable horizontally.
Identify the motherboard in the rear casing.
Remove the ground cable from the motherboard by gently lifting it up as shown.
Remove the six 6mm Phillips #2 screws from the perimeter of the motherboard.
Remove the motherboard by gripping the rubber stopper as shown and lifting the motherboard up out of its plastic housing.
Carefully flip the motherboard over and locate the nineteen capacitors.
Notice the six cables attached to the motherboard. Pull on each cable connector with moderate to heavy force to remove them.
Remove the two 12mm Phillips #2 screws from each side of the speaker.
Repeat the same process for the other speaker.
Lift up each speaker to remove it from the TV. The wires should already be unplugged from the motherboard and the speakers should now be completely isolated.
