주요 콘텐츠로 건너뛰기
RCA 8 Apollo Camera Replacement
필요한 것
  1. RCA 8 Apollo Camera Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your tablet before beginning to disassemble.
  2. RCA 8 Apollo Camera Replacement: 2 단계, 이미지 2개 중 1개 RCA 8 Apollo Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Insert an iFixit opening tool into the gap between the tablet and back panel.
    • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
    • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
  3. RCA 8 Apollo Camera Replacement: 3 단계, 이미지 2개 중 1개 RCA 8 Apollo Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the red and black speaker wires from the tablet.
    • The front and back of the tablet will be disconnected.
  4. RCA 8 Apollo Camera Replacement, Display Assembly: 4 단계, 이미지 3개 중 1개 RCA 8 Apollo Camera Replacement, Display Assembly: 4 단계, 이미지 3개 중 2개 RCA 8 Apollo Camera Replacement, Display Assembly: 4 단계, 이미지 3개 중 3개
    • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
    • Remove the yellow tape that is around the battery.
    • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
    • If the connector is misaligned, the pins can bend, causing permanent damage.
  5. RCA 8 Apollo Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the three screws from the motherboard using a Phillips screwdriver.
  6. RCA 8 Apollo Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the battery and motherboard together from the tablet.
    • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
    • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
  7. RCA 8 Apollo Camera Replacement, Camera: 7 단계, 이미지 2개 중 1개 RCA 8 Apollo Camera Replacement, Camera: 7 단계, 이미지 2개 중 2개
    • Remove the front facing and back facing cameras from the top of the tablet.
결론
작성자
1다른 기여자 명과 함께
Chantel Pfiefer
회원 가입일: 04/15/24
219 평판
안내서 2개를 작성함
Casper College, Team 1-1, Lareau Spring 2024 Casper College, Team 1-1, Lareau Spring 2024 회원
CASC-LAREAU-S24S1G1
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 6
전체 시간: 82
