주요 콘텐츠로 건너뛰기
RCA 8 Apollo Volume Button Replacement
필요한 것
  1. RCA 8 Apollo Volume Button Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your tablet before beginning to disassemble.
  2. RCA 8 Apollo Volume Button Replacement: 2 단계, 이미지 2개 중 1개 RCA 8 Apollo Volume Button Replacement: 2 단계, 이미지 2개 중 2개
    • Insert an iFixit opening tool into the gap between the tablet and back panel.
    • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
    • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
  3. RCA 8 Apollo Volume Button Replacement: 3 단계, 이미지 2개 중 1개 RCA 8 Apollo Volume Button Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the red and black speaker wires from the tablet.
    • The front and back of the tablet will be disconnected.
  4. RCA 8 Apollo Volume Button Replacement, Volume Button: 4 단계, 이미지 1개 중 1개
    • The volume button control pad is located in the back panel, on the right side of the tablet.
    • Push on the outside of the volume button control pad and it will simply loosen and detach.
결론
작성자
1다른 기여자 명과 함께
Brooke Still
회원 가입일: 04/12/24
123 평판
안내서 1개를 작성함
Casper College, Team 1-1, Lareau Spring 2024 Casper College, Team 1-1, Lareau Spring 2024 회원
CASC-LAREAU-S24S1G1
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 77
