이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the six 7.9mm Phillips #0 screws on the back and bottom.
Remove the one 3.8mm Phillips #0 screw on the bottom.
Remove the two 7.5mm Phillips #0 screws on the back and bottom.
Remove 5.8mm Phillips #1 screw from the side button panel.
Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
Pull the left panel away from the rest of the camcorder.
Unplug the red speaker cable located at the rear of the device.
Pull back the plastic tabs along the edges of the motherboard.
Disconnect all the cables along the left side of the motherboard.
Disconnect all cables along the bottom of the motherboard.
Pull the motherboard away from the camcorder.
Desolder the two black wires holding the motherboard to the camcorder using a soldering iron.
다른 한 분이 해당 안내서를 완성하였습니다.
