주요 콘텐츠로 건너뛰기
RCA CC310 Onboard Microphone Replacement
필요한 것
  1. RCA CC310 Onboard Microphone Replacement, Onboard Microphone: 1 단계, 이미지 1/2 RCA CC310 Onboard Microphone Replacement, Onboard Microphone: 1 단계, 이미지 2/2
    • Lift the metal flap and slide the viewfinder off to the right.
  2. RCA CC310 Onboard Microphone Replacement: 2 단계, 이미지 1/3 RCA CC310 Onboard Microphone Replacement: 2 단계, 이미지 2/3 RCA CC310 Onboard Microphone Replacement: 2 단계, 이미지 3/3
    • Unscrew the 7.0mm ph#0 screw on the underside where the cable connects.
    • Lift the plastic where the cable is connected to the viewfinder.
    • Disconnect the cable inside by pulling it apart.
  3. RCA CC310 Onboard Microphone Replacement: 3 단계, 이미지 1/2 RCA CC310 Onboard Microphone Replacement: 3 단계, 이미지 2/2
    • Unscrew the two 7mm ph#0 screws on the underside of the viewfinder assembly.
    • Lift the viewfinder plastic assembly up.
  4. RCA CC310 Onboard Microphone Replacement: 4 단계, 이미지 1/2 RCA CC310 Onboard Microphone Replacement: 4 단계, 이미지 2/2
    • Lift the microphone circuit board straight up.
    • Unclip the cable connected to the circuit board.
  5. RCA CC310 Onboard Microphone Replacement: 5 단계, 이미지 1/1
    • Turn the microphone circuit board over.
    • Unscrew the two Ph#0 screws holding the plastic housing on the circuit board.
  6. RCA CC310 Onboard Microphone Replacement: 6 단계, 이미지 1/1
    • Desolder the metal protective housing using a soldering iron.
    • Desolder the microphone and replace it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Oliver Adams
회원 가입일: 01/19/11
629 평판
안내서 6개 작성하였습니다
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G20
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 15
전체 시간: 927
