이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Unscrew the 7.0mm ph#0 screw on the underside where the cable connects.
Lift the plastic where the cable is connected to the viewfinder.
Disconnect the cable inside by pulling it apart.
Unscrew the two 7mm ph#0 screws on the underside of the viewfinder assembly.
Lift the viewfinder plastic assembly up.
Lift the microphone circuit board straight up.
Unclip the cable connected to the circuit board.
Turn the microphone circuit board over.
Unscrew the two Ph#0 screws holding the plastic housing on the circuit board.
Desolder the metal protective housing using a soldering iron.
Desolder the microphone and replace it.
다른 한 분이 해당 안내서를 완성하였습니다.
