주요 콘텐츠로 건너뛰기
RCA CC310 Onboard Speaker Replacement
필요한 것
  1. RCA CC310 Onboard Speaker Replacement, Disassembling RCA CC310 Left Cover: 1 단계, 이미지 1/2 RCA CC310 Onboard Speaker Replacement, Disassembling RCA CC310 Left Cover: 1 단계, 이미지 2/2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. RCA CC310 Onboard Speaker Replacement: 2 단계, 이미지 1/2 RCA CC310 Onboard Speaker Replacement: 2 단계, 이미지 2/2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. RCA CC310 Onboard Speaker Replacement: 3 단계, 이미지 1/2 RCA CC310 Onboard Speaker Replacement: 3 단계, 이미지 2/2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. RCA CC310 Onboard Speaker Replacement: 4 단계, 이미지 1/2 RCA CC310 Onboard Speaker Replacement: 4 단계, 이미지 2/2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  5. RCA CC310 Onboard Speaker Replacement, Onboard Speaker: 5 단계, 이미지 1/2 RCA CC310 Onboard Speaker Replacement, Onboard Speaker: 5 단계, 이미지 2/2
    • Unplug the red cable connecting the speaker to the motherboard.
  6. RCA CC310 Onboard Speaker Replacement: 6 단계, 이미지 1/2 RCA CC310 Onboard Speaker Replacement: 6 단계, 이미지 2/2
    • Locate the speaker on the removed panel. Find the groove on the top left side of the speaker.
    • Pry the plastic up with a spudger until the glue breaks and the speaker is detached.
  7. RCA CC310 Onboard Speaker Replacement: 7 단계, 이미지 1/1
    • Break the plastic pieces holding the cable to the panel.
    • Glue the new cables, with a hot glue gun, back to the panel after replacing the speaker.
  8. RCA CC310 Onboard Speaker Replacement: 8 단계, 이미지 1/3 RCA CC310 Onboard Speaker Replacement: 8 단계, 이미지 2/3 RCA CC310 Onboard Speaker Replacement: 8 단계, 이미지 3/3
    • Glue the new speaker to the panel.
    • Plug the cable back into the motherboard.
결론
Oliver Adams
회원 가입일: 01/19/11
629 평판
안내서 6개 작성하였습니다
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G20
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 995
