주요 콘텐츠로 건너뛰기
RCA CC310 Viewfinder Replacement
필요한 것
  1. RCA CC310 Viewfinder Replacement, Viewfinder: 1 단계, 이미지 1/2 RCA CC310 Viewfinder Replacement, Viewfinder: 1 단계, 이미지 2/2
    • Slide a spudger between the plastic rail and the metal tab on the left side of the rail. Push away from the camcorder to release the flap.
    • Pushing the viewfinder assembly to the right makes lifting the flap easier.
    • Slide the lifted flap towards the viewfinder assembly until the viewfinder is free from the rail.
  2. RCA CC310 Viewfinder Replacement: 2 단계, 이미지 1/3 RCA CC310 Viewfinder Replacement: 2 단계, 이미지 2/3 RCA CC310 Viewfinder Replacement: 2 단계, 이미지 3/3
    • Unscrew the 7mm ph#0 screw on the underside where the cable connects.
    • Lift the plastic where the cable connects off of the viewfinder assembly.
    • Disconnect the cable inside by pulling it apart.
  3. RCA CC310 Viewfinder Replacement: 3 단계, 이미지 1/2 RCA CC310 Viewfinder Replacement: 3 단계, 이미지 2/2
    • Unscrew two 7.0mm ph#0 screws on the underside of the viewfinder assembly.
    • Lift the viewfinder plastic assembly up and remove.
  4. RCA CC310 Viewfinder Replacement: 4 단계, 이미지 1/1
    • Flip back the viewfinder access tab.
    • Unscrew the 7.0mm ph #0 screw next to the mirror.
  5. RCA CC310 Viewfinder Replacement: 5 단계, 이미지 1/3 RCA CC310 Viewfinder Replacement: 5 단계, 이미지 2/3 RCA CC310 Viewfinder Replacement: 5 단계, 이미지 3/3
    • Lift off both sides of the plastic assembly.
    • When reassembling, if the housing doesn't connect properly, try turning the focus wheel.
  6. RCA CC310 Viewfinder Replacement: 6 단계, 이미지 1/2 RCA CC310 Viewfinder Replacement: 6 단계, 이미지 2/2
    • Lift the microphone circuit board straight up.
    • Unclip the cable connected to the circuit board.
  7. RCA CC310 Viewfinder Replacement: 7 단계, 이미지 1/3 RCA CC310 Viewfinder Replacement: 7 단계, 이미지 2/3 RCA CC310 Viewfinder Replacement: 7 단계, 이미지 3/3
    • Lift plastic housing and guide the wires from underneath.
    • Lift out the entire circuit board and viewfinder.
    • Replace entire circuit board and viewfinder assembly.
결론
Oliver Adams
회원 가입일: 01/19/11
629 평판
안내서 6개 작성하였습니다
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G20
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
do you know where i can find a relacement one of these parts
Connor Byrley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 2,267
