  1. Remove the two Phillips screws from the silver cover at the top of the Lyra. Slowly wiggle the silver cover while pulling it away from the device.
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  2. Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button. Pull the silver case from the bottom of the device.
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  3. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  4. Carefully pry up the screen with a plastic opening tool. Disconnect the screen's ribbon cable  from the circuit board. Remove the screen.
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  5. Open the case of the Lyra. Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  6. Locate the audio jack on the Lyra X2400. If you have difficulty locating this component look at the picture to the left. Start using the solder/desolder tools to remove this component.
    • Locate the audio jack on the Lyra X2400. If you have difficulty locating this component look at the picture to the left.
    • Start using the solder/desolder tools to remove this component.
    • Once removed replace the old audio jack with a new audio jack.
    • Use soldering tools to reattach this component back to the main logic board.
결론
Joseph Goodwin
회원 가입일: 2013년 04월 11일
1 Reputation
안내서 5개 작성하였습니다
Cal Poly, Team 17-3, Regan Spring 2013 Cal Poly, Team 17-3, Regan Spring 2013 회원
CPSU-REGAN-S13S17G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 143
