소개
Use this guide to replace the USB port of the RCA Lyra X2400.
  1. Remove two Phillips screws from the silver cover at the top of the Lyra. Slowly wiggle the silver cover while pulling it away from the device.
    • Remove two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  2. Remove two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button. Pull the silver case from the bottom of the device.
    • Remove two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Carefully pry up the screen with a plastic opening tool. Disconnect the screen's ribbon cable  from the circuit board. Remove the screen.
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  5. Open the case of the Lyra. Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  6. Locate the USB in/out component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located. Start using solder/desolder tools to remove the USB in/out.
    • Locate the USB in/out component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located.
    • Start using solder/desolder tools to remove the USB in/out.
    • Once removed replace it with the new working USB in/out.
    • Use the soldering tools to reattach the component back to the main logic board.
결론
Joseph Goodwin
회원 가입일: 2013년 04월 11일
1 평판
안내서 5개 작성하였습니다
Cal Poly, Team 17-3, Regan Spring 2013 Cal Poly, Team 17-3, Regan Spring 2013 회원
CPSU-REGAN-S13S17G3
4 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 143
