주요 콘텐츠로 건너뛰기
RCA Lyra X2400 flash card reader replacement
필요한 것
  1. RCA Lyra X2400 flash card reader replacement, Battery: 1 단계, 이미지 1/3 RCA Lyra X2400 flash card reader replacement, Battery: 1 단계, 이미지 2/3 RCA Lyra X2400 flash card reader replacement, Battery: 1 단계, 이미지 3/3
    • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
    • Remove the battery plate.
    • Place your finger at the bottom of the battery.
    • Lift up on the battery until it pops out from the LYRA X2400.
  2. RCA Lyra X2400 flash card reader replacement, Screen: 2 단계, 이미지 1/2 RCA Lyra X2400 flash card reader replacement, Screen: 2 단계, 이미지 2/2
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  3. RCA Lyra X2400 flash card reader replacement: 3 단계, 이미지 1/2 RCA Lyra X2400 flash card reader replacement: 3 단계, 이미지 2/2
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  4. RCA Lyra X2400 flash card reader replacement: 4 단계, 이미지 1/3 RCA Lyra X2400 flash card reader replacement: 4 단계, 이미지 2/3 RCA Lyra X2400 flash card reader replacement: 4 단계, 이미지 3/3
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  5. RCA Lyra X2400 flash card reader replacement, Motherboard: 5 단계, 이미지 1/2 RCA Lyra X2400 flash card reader replacement, Motherboard: 5 단계, 이미지 2/2
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  6. RCA Lyra X2400 flash card reader replacement, Compact Flash Card: 6 단계, 이미지 1/2 RCA Lyra X2400 flash card reader replacement, Compact Flash Card: 6 단계, 이미지 2/2
    • Locate the compact flash card slot on the logic board. For assistance on locating this component look at the picture to the left.
    • Use soldering/desoldering tools to remove the compact flash card.
    • Replace compact flash card and use soldering tools to complete the replacement.
결론
Joseph Goodwin
회원 가입일: 04/11/13
1 평판
안내서 5개 작성하였습니다
Cal Poly, Team 17-3, Regan Spring 2013 Cal Poly, Team 17-3, Regan Spring 2013 회원
CPSU-REGAN-S13S17G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 226
