주요 콘텐츠로 건너뛰기
RCA Maven Pro 11 Motherboard Replacement
필요한 것
  1. RCA Maven Pro 11 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 RCA Maven Pro 11 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 RCA Maven Pro 11 Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Use a Phillip's head screwdriver to unscrew the screws that secure the back cover in place. There are 6 screws in total (4 black, 2 silver).
  2. RCA Maven Pro 11 Motherboard Replacement: 2 단계, 이미지 1/3 RCA Maven Pro 11 Motherboard Replacement: 2 단계, 이미지 2/3 RCA Maven Pro 11 Motherboard Replacement: 2 단계, 이미지 3/3
    • Using a prying tool to pry off the back cover of the tablet. To do this, insert the prying tool between the screen and the side of the tablet.
    • Once the prying tool is inserted, run it along the edge of the tablet until the back cover pops off.
  3. RCA Maven Pro 11 Motherboard Replacement: 3 단계, 이미지 1/1
    • Use a Phillips head screwdriver to unscrew the 4 black screws that secure the motherboard to the device.
  4. RCA Maven Pro 11 Motherboard Replacement: 4 단계, 이미지 1/3 RCA Maven Pro 11 Motherboard Replacement: 4 단계, 이미지 2/3 RCA Maven Pro 11 Motherboard Replacement: 4 단계, 이미지 3/3
    • On the long edge of the motherboard, remove all of the ribbon and bundled cables.
    • The ZIF connections are removed by lifting up the small black tab on the connector and simply pulling out the ribbon cable(s).
    • Insert a spudger or plastic opening tool under the lip of the white bundled cable connector(s), and push the connector(s) free.
  5. RCA Maven Pro 11 Motherboard Replacement: 5 단계, 이미지 1/3 RCA Maven Pro 11 Motherboard Replacement: 5 단계, 이미지 2/3 RCA Maven Pro 11 Motherboard Replacement: 5 단계, 이미지 3/3
    • On the short edge of the motherboard, remove the yellow wire. To do this, lift up the clamp and pull out the wire.
  6. RCA Maven Pro 11 Motherboard Replacement: 6 단계, 이미지 1/1
    • Lift motherboard off the back of the tablet.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Hailey Souder
회원 가입일: 03/04/19
210 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 537
