주요 콘텐츠로 건너뛰기
RCA Pro10 Edition Power/Volume Buttons Replacement
필요한 것
  1. RCA Pro10 Edition Power/Volume Buttons Replacement, Speaker: 1 단계, 이미지 2개 중 1개 RCA Pro10 Edition Power/Volume Buttons Replacement, Speaker: 1 단계, 이미지 2개 중 2개
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Power/Volume Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Power/Volume Buttons Replacement: 3 단계, 이미지 2개 중 1개 RCA Pro10 Edition Power/Volume Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
  4. RCA Pro10 Edition Power/Volume Buttons Replacement, Camera: 4 단계, 이미지 3개 중 1개 RCA Pro10 Edition Power/Volume Buttons Replacement, Camera: 4 단계, 이미지 3개 중 2개 RCA Pro10 Edition Power/Volume Buttons Replacement, Camera: 4 단계, 이미지 3개 중 3개
    • Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
    • Peel back the beige tape while holding down the camera ribbon cable to prevent tears
  5. RCA Pro10 Edition Power/Volume Buttons Replacement: 5 단계, 이미지 2개 중 1개 RCA Pro10 Edition Power/Volume Buttons Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the locking tab that is securing the camera ribbon cable.
    • Slide the ribbon cable out from the connector and remove from casing.
  6. RCA Pro10 Edition Power/Volume Buttons Replacement, Power/Volume Buttons: 6 단계, 이미지 1개 중 1개
    • Use a P00 Phillips screwdriver to remove the three screws securing the button board.
    • Desolder the contacts on the button board to remove or replace it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Dayne Russell
회원 가입일: 01/27/15
404 평판
안내서 4개를 작성함
Pasco Hernando, Team 1-1, Prince Winter 2015 Pasco Hernando, Team 1-1, Prince Winter 2015 회원
PHSC-PRINCE-W15S1G1
6 회원들
안내서 10개를 작성함
1가이드 댓글
What is the part number for the Power/Volume Buttons? Where can I purchase one?
EvanSnow - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 1,145
