주요 콘텐츠로 건너뛰기
RCA Pro10 Edition Speaker Replacement
필요한 것
  1. RCA Pro10 Edition Speaker Replacement, Speaker: 1 단계, 이미지 1/2 RCA Pro10 Edition Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Speaker Replacement: 2 단계, 이미지 1/1
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Speaker Replacement: 3 단계, 이미지 1/2 RCA Pro10 Edition Speaker Replacement: 3 단계, 이미지 2/2
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
결론
Dayne Russell
회원 가입일: 01/27/15
401 평판
안내서 4개 작성하였습니다
Pasco Hernando, Team 1-1, Prince Winter 2015 Pasco Hernando, Team 1-1, Prince Winter 2015 회원
PHSC-PRINCE-W15S1G1
6 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 749
