주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RCA RCT6203W46 Screen/Digitizer Replacement
조회수: 3.8천
통계 보기:
지난 24시간
3
지난 7일:
16
지난 30일:
77
전체 시간:
3,796
댓글: 2
1 comment on steps, 1 guide comment.
Go to guide comments
완료함: 4
4명이 이 안내서를 "완료"로 표시했습니다. 다음은 귀하의 차례입니까?
즐겨찾기: 3
3명이 이 가이드를 즐겨찾기 (및 구독) 했습니다. 다음은 귀하의 차례입니까?
소요 시간: 45 분 - 2 시간
난이도: 어려움
To avoid damaging the LCD, this guide removes the screen/digitizer from the rear of the device. This replacement requires patience as removing the screen can be tedious. Along with the listed tools, thin, sturdy wedges such as playing cards or guitar picks can greatly simplify and expedite screen removal.
필요한 것
도구
    1. RCA RCT6203W46  Screen/Digitizer Replacement, Screen/Digitizer: 1 단계, 이미지 2개 중 1개 RCA RCT6203W46  Screen/Digitizer Replacement, Screen/Digitizer: 1 단계, 이미지 2개 중 2개
      • Remove these four 4 mm Phillip's #00 screws.
      댓글 쓰기
    2. RCA RCT6203W46  Screen/Digitizer Replacement: 2 단계, 이미지 2개 중 1개 RCA RCT6203W46  Screen/Digitizer Replacement: 2 단계, 이미지 2개 중 2개
      • Run a spudger tool around the edge of the screen to loosen it and begin to pry upward.
      • The screen will be able to be removed once you see it pop up like it has in the photo.
      • There are wires attached to the back cover and screen so be careful not to pull them apart.
      댓글 쓰기
    3. RCA RCT6203W46  Screen/Digitizer Replacement: 3 단계, 이미지 3개 중 1개 RCA RCT6203W46  Screen/Digitizer Replacement: 3 단계, 이미지 3개 중 2개 RCA RCT6203W46  Screen/Digitizer Replacement: 3 단계, 이미지 3개 중 3개
      • Unclip the three ribbon cables from the motherboard by lifting up on their latches (the black portions that the cables feed into) and gently pulling the cables.
      • The process is the same for all three ribbon wires.
      • Do not forcefully try to remove the cables. The latch may not be lifted up all the way, and using force can separate the cable from its connector, which can damage important components of the tablet.
      댓글 쓰기
    4. RCA RCT6203W46  Screen/Digitizer Replacement: 4 단계, 이미지 1개 중 1개
      • To remove the battery, gently pry underneath it and around the edges with your spudger. This will pull it off of the adhesive keeping it on the case.
      • The battery will slightly deform while trying to remove it. This is normal, though try to limit the amount of deformation.
      • DO NOT puncture the battery as this may cause fire or explosion.
      댓글 쓰기
    5. RCA RCT6203W46  Screen/Digitizer Replacement: 5 단계, 이미지 2개 중 1개 RCA RCT6203W46  Screen/Digitizer Replacement: 5 단계, 이미지 2개 중 2개
      • Carefully peel off these two pieces of tape to remove the antenna.
      댓글 쓰기
    6. RCA RCT6203W46  Screen/Digitizer Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the three 4 mm Phillip's #00 screws from the motherboard. Then carefully lift off the motherboard from the screen.
      • You may need to use a prying tool to lift the motherboard off the screen, though using your fingers should work.
      댓글 쓰기
    7. RCA RCT6203W46  Screen/Digitizer Replacement: 7 단계, 이미지 3개 중 1개 RCA RCT6203W46  Screen/Digitizer Replacement: 7 단계, 이미지 3개 중 2개 RCA RCT6203W46  Screen/Digitizer Replacement: 7 단계, 이미지 3개 중 3개
      • To remove the LCD from the screen casing, gently pry it out of the clips that are holding it in place.
      • If possible, use a plastic spudger. However, since the clips are tight, a metal spudger may be necessary.
      • Use of playing cards or guitar picks help to keep the clips from reattaching themselves to the device.
      • Focus on one half of the LCD, as the other half will come out easily when the first half comes loose.
      • Be careful not to damage the clips or LCD when prying.
      댓글 쓰기
    8. RCA RCT6203W46  Screen/Digitizer Replacement: 8 단계, 이미지 2개 중 1개 RCA RCT6203W46  Screen/Digitizer Replacement: 8 단계, 이미지 2개 중 2개
      • With a heat gun, heat along the border of the screen and case to weaken the glue.
      • Do not leave the heat gun pointed in one spot for long. This may warp or melt the plastic and make reassembly more difficult.
      댓글 쓰기
    9. RCA RCT6203W46  Screen/Digitizer Replacement: 9 단계, 이미지 1개 중 1개
      • Slide a spudger around the edge of the screen. This will disconnect the black edge from the frame.
      • A plastic opening tool may help insert the spudger between the frame and the screen.
      • You may need to reheat sections of the border if sliding the spudger becomes difficult.
      댓글 쓰기
    10. RCA RCT6203W46  Screen/Digitizer Replacement: 10 단계, 이미지 1개 중 1개
      • Starting from one end, use a plastic opening tool to lift the frame away from the screen.
      • As before, you may need to reheat sections to weaken the glue.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자
Alexis Roberson
회원 가입일: 09/21/16
344 평판
안내서 1개를 작성함
팀
UC Davis, Team 1-2, Oliver Fall 2016 UC Davis, Team 1-2, Oliver Fall 2016 회원
UCD-OLIVER-F16S1G2
5 회원들
안내서 48개를 작성함
1가이드 댓글
How can I find the LCD screen for at 10.1 RCA PRO 10 Edition RCT6203W46 WJ610-V2.0
Mya Haydel - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 77
전체 시간: 3,796
